11-13-2021
16:01
17:04
EdsonFitbit
11-13-2021
16:01
17:04
EdsonFitbit
As I learned today the Luxe got an AOD option last month. Its clock with seconds and its small size makes it the wearable Ive been waiting for for years. Nice Fitbit, many thanks.
The clock face Liberty tho. I can see from pictures that it has a digital clock in the middle and some kind of analog indicators around it. What exactly are the analog indidicators and does this clock face display seconds?
Or are there any other means to tell how far a minute has progressed with the Liberty clock face like with the Energy clock face on the Charge 5 where a bar progresses every few seconds?
Thanks
11-14-2021 18:19
11-14-2021 18:19
No clock face in Luxe does what you ask.
Liberty clockface show alternatively only HR and AZM, no seconds.
Best Answer11-16-2021 16:41 - edited 11-17-2021 14:58
Thank you for visiting the Fitbit Community, @llhiatus.
Thanks for your kind words about the Fitbit Luxe design.
This clock face Liberty has a digital clock in the middle, like you mentioned, that shows the hour and minutes only. The digital clock is surrounded by colored lines. On its left side it shows the day of the week and date (TU 28) and on the right side your Active Zone Minutes. Luxe clock faces don't show seconds when in always-on display mode.
Thanks for your comment, @Guitarplayer.
See you around.
Best Answer11-16-2021 18:39
11-16-2021 18:39
Only digital clock with seconds I can find is Hawaiian Punch but seconds are not shows in always on mode
Best Answer11-17-2021 15:00
11-17-2021 15:00
Sorry for the misunderstanding. I just verified the seconds are deactivated in all Luxe clock faces when in always-on display mode. I just edited my response above to avoid any confusion.
Have a nice day.
Best Answer11-19-2021 08:40
11-19-2021 08:40
Can you change the colors of the faces like on an apple watch? Some have functional design but not really looking for a pink watch face...
Best Answer11-22-2021 16:17
11-22-2021 16:17
Welcome to the Fitbit Community, @BT714.
Thank you for your question.
There is a Feature Suggestion called "Able to customize design and color of Luxe clock faces". You are welcome to vote it and if there is any update, it should be communicated as soon as possible.
See you around.
