10-08-2021 07:52
10-08-2021 07:52
Have Luxe and need to delete data from past fitbits
Best Answer10-08-2021 19:34
10-08-2021 19:34
Hi @lkhenne you getting rid of your unused devices? Once they are removed from you account, none of your personal information remains on them. Your data is kept on the Fitbit servers under your unique email and password. Was that what you needed?
Best Answer10-09-2021 05:21
10-09-2021 05:21
Thank you for the information. How do you remove them from your account?
Best Answer10-09-2021 05:33
10-09-2021 05:33
@lkhenne go to the app settings (or from the website) and see what is listed on your account. You would normally only have one Fitbit on there as each one you set up removes the one before it. If there is more than one listed, you'd click on it to remove it. Once you set up the new Luxe, it should be the only Fitbit listed on your account.
Best Answer10-09-2021 11:53
10-09-2021 11:53
It is the only Fitbit listed but all the old data show from old Fitbits still shows up
Best Answer10-09-2021 11:56
10-09-2021 11:56
Ahh, ok @lkhenne your history from the steps and activities will show if you use the same account. Easiest way to start fresh is a new account with a new email address. You can also just delete the old account and then start a new one with your email address.
