When I try to use my timer app on luxe it is often difficult to get it to return to clock. So I changed my display to symphony and attempt to time with that. Short times like eggs or other kitchen uses. The symphony clock face minute hand is not very accurate. its good @ 0, 15, 30, 45 , but other times its hard to tell exactly. Every other function on the device is so exact and precise I?
Best AnswerHi, @magicalbutter, welcome, I recognise your problem, there is very little room on the Luxe screen. You could use the countdown timer or alternatively Siri or your google assistant on your mobile phone.
I hope this helps.
Cheers
Gr4ndp4 | UK
