I find it helpful to monitor my body fat instead of my overall weight but there is no dedicated graph on the dashboard/log that shows me this. There is only a "Lean vs Fat" graph.
I would like a line graph that plots my body fat (ie weight x body fat %) in kg and include a "line of best fit".
This would make it easier for me to identify changes in my weight.
At the moment I am exporting the data into Excel and then creating the graph.
@S_I_M: this is what the TrendWeight body fat chart mentioned by @A_Lurker looks like:
You can easily change the period by clicking on the corresponding tab on top of the graph. Units are kg for me, but they could be lb for you (depending on what you’re using in Fitbit). Weight/BF graphs in TrendWeight are more legible than those in Fitbit IMO.
Dominique | Finland
@S_I_M- you could link your account to trendweight.com to track your changes. It does total weight, fat %, fat mass and lean mass. You can also put in a feature suggestion: https://community.fitbit.com/t5/Feature-Suggestions/idb-p/features - you may want to check if someone has already asked for this as well.
Anne | Rural Ontario, Canada
Ionic (gifted), Alta HR (gifted), Charge 2, Flex 2, Charge HR, One, Blaze (retired), Trendweight.com,
Down 150 pounds from my top weight (and still going), sharing my experiences here to try and help others.
I've added this as a new feature
https://community.fitbit.com/t5/Feature-Suggestions/Body-Fat-Graph-on-Dashboard-Log/idi-p/1861373
but I couldn't delete the old dupplicate message
Dominique | Finland
