11-28-2019 00:08
11-28-2019 00:08
Hi Fitbit,
I was wandering if there is a way to set a goal for my body fat % instead of a weight goal.
The idea of just the loss of 'weight' for me is not a healthy goal. I know i can track my fat% aswell but I would love to change the overall weightgoal into a fat% goal. or a Lean mass goal.
This because I do a lot of weight training that increases my weight by muscle mass and i'm losing fat%. Overall that means that my weight in total stay almost the same. But none the less the 'weight' goal is a huge one for me 🙂
Best Answer11-28-2019 02:15
11-28-2019 02:15
It's not possible at the moment. I did find a feature suggestion for it though. If you'd like to add your vote you can find it here: https://community.fitbit.com/t5/Feature-Suggestions/Body-Fat-as-Main-Goal-Instead-of-Weight/idi-p/20...
Note though that it only has 12 votes so far in over two years. Unless it gets a lot more votes it's unlikely to influence the fitbit development teams.
Best Answer11-28-2019 02:22
11-28-2019 02:22
I've just reread that feature suggestion. There's a comment in there from a moderator (from 2017) saying that you can set this goal now. Have a look and see if it works for you.
