03-29-2017 11:51 - edited 03-29-2017 12:19
Hi! I bought 2 weeks ago a Fitbit aria scale. Since then my body fat % decreased from 34% to 32% (roughly). Then, today I had a meeting in the gym and they use the Omron Body Composition Monitor And Scale. Surprise then! almost 40% of body fat. I had another body fat measure 2 months ago, and the body fat % barely dropped (0.2%). Omron scale also says (as Fitbit) that I dropped weight (2kg).
I am in shock! Why this almost 8% of difference?
Best Answer03-29-2017 12:37
03-29-2017 12:37
You just have to accept these devices only provide estimates. For optimal results, you should use the same device under the same conditions. They may not be accurate in absolute terms, but at least they should be consistent and should show you the right trend over time. For instance your Aria first thing in the morning. Also note two weeks is a very short period of time, especially for a woman (impact of hormonal cycle). The value of your Aria will come after you’ve been using it for long enough. I’d also suggest you link your Fitbit account to Trendweight, which displays weight and body fat% data in a more legible way IMO. As an example, here is my full BF history over four years:
You can switch between periods and metrics via the tabs at the top (when on the TrendWeight site).
Dominique | Finland
