01-26-2014 06:48
01-26-2014 06:48
In the begiunning, you couls set and adjust your weight goals along with others. Now there is no option to do that.
Best Answer01-27-2014 06:39
01-27-2014 06:39
If you do a search you will find your answer
Short version:
Webpage Dashboard: click the setings (gear) icon bottom left side of the Weight Tile then click the edit icon (pencil), modify your goal weight
Ios application: Click the account tab at the bottom, then click the Goals tab then click the Food (calorie deficit) under Diet, Modifiy your goal weight
Hope this helps, keep on fitbiting!
