04-28-2017 05:52
04-28-2017 05:52
In the calories in vs calories out section on the app, is it better to be 'in the zone' or under? 🙂
Best Answer04-28-2017 06:05
04-28-2017 06:05
What is better depends on how you have set it up. But if you set up a weight loss plan with a calories deficit, then that is already taken into account and you can aim for hitting the zone. Being under the zone would result in an even bigger calories deficit than the one you planned for.
Karolien | The Netherlands
Best Answer04-28-2017 06:10
04-28-2017 06:10
Best Answer04-28-2017 07:21
04-28-2017 07:21
Yes, bigger deficit = faster weight loss, but that doesn’t necessarily mean it’s better. You need to consider sustainability too. If you’ve just started to use the food plan, you may want to stick to the planned deficit (= stay in the zone) for a while, and see if your weight change matches the predicted loss or not.
Dominique | Finland
Best Answer04-28-2017 07:28
04-28-2017 07:28
Best Answer04-28-2017 09:54
04-28-2017 09:54
I don't pay much attention to if I'm in the zone at any particular point in the day. In fact, I plan and log my food for the day first thing in the morning. As long as I hit my calorie deficit at the end of the day, I'm happy.
Best Answer04-29-2017 17:05
04-29-2017 17:05
I'm kind of the same as @glitterNfunk whether I'm logging or not. I don't bother checking during the day, just do kind of a quick recap at the end of the day and adjust based on where I am.
Anne | Rural Ontario, Canada
Ionic (gifted), Alta HR (gifted), Charge 2, Flex 2, Charge HR, One, Blaze (retired), Trendweight.com,
Down 150 pounds from my top weight (and still going), sharing my experiences here to try and help others.
