i bought my fitbit last May 2016 , surprisingly i lost till september 2016, 10 pounds and counting , came from 107kgs to 92 kgs even I could achieve 88 kgs . But , since that date and keeping the same structure and movement and types of food , i am gaining weight !!!!!! , at least this Cxhtmas season i am 2 pounds fatter than I was at closing Nov 2016 .......
Really don't know what to do .... and my Fitbir still advicing the same 1000 calories i saved everyday between calories burn vs calories eated ....
Help !
Best Answer1800cal eated VS 3100cal burned both averaged
Best AnswerHave you tried changing your exercise at all? The body is an amazing adaptive machine. It learns to be efficient as possible in a relatively short period of time. If you start working out, even if it is walking more, your body adapts to the new exercise. Initially it will not be very economical in energy conservation when adapting to a new workout, but it won't take long for it to do it very efficiently, effectively reducing the number of calories you are burning for the exact same exercise. Also add in the loss of 10 pounds and it is using even less calories because you are hauling less weight all the time.
In the past, I lost a large amount of weight (50+ pounds). When I hit a plateau I tried to shake things up with my exercise. Also, I don't eat the same # calories every day. I generally eat what I burn at least one day a week, while other days I might have a bigger than normal deficit. I'm happy if at the end of the week I average out to my goal deficit.
For me, keeping my body guessing has worked very well. Also, I don't know how much more you want to lose, but it is very different when you get to those last 10-15 pounds. It required a lot more effort on my part. Good luck!
