08-04-2023 19:25
08-04-2023 19:25
Is there a way to manually adjust calorie recommendation? My device is regularly telling me, a 5’3” adult maintaining weight, to eat under 1500 calories/day (at the end, not beginning, of the day).
08-04-2023 19:29
08-04-2023 19:29
Also: at the end of days where I’ve walked over 3 miles, it still recommends fewer than 1900 calories.
Best Answer08-05-2023 05:31 - edited 08-05-2023 05:38
Hello @SunsetRunner and welcome to the Community. Your calorie recommendation comes from two sources, your BMR calories plus activity calories. Fitbit uses the Mifflin St Jeor equation to estimate your BMR calories. It uses your sex, age, height, and weight. Try this easy to use online calculator to estimate yours. It's hard to estimate the impact of daily distance. Activity calories are also based on those same factors. But there is a difference between walking three miles at one time and walking three miles over a whole day.
1500 calories seems reasonable for someone your height and level of activity, even though I don't know everything else about you.
I'm moving your post to the Manage Weight forum. I think it is a better fit for your question.
Laurie | Maryland
08-05-2023 22:00
08-05-2023 22:00
My metabolic rate is medically increased, so I guess the issue is actually that I’m not within the standard. There’s no way to change my caloric needs?
Best Answer08-05-2023 22:02
08-05-2023 22:02
(Same person as OP, for clarification—also, thank you!)
Best Answer08-06-2023 06:01
08-06-2023 06:01
@embalmo Medication is one factor that will affect BMR. Body composition is another. There isn't any way to change the number that Fitbit calculates for you. If your goal is to maintain, but you are losing weight on the Food Plan recommendation, I think the only option to eat more.
Laurie | Maryland
08-11-2023 06:08
08-11-2023 06:08
It's essential to maintain a healthy calorie intake that suits your needs. While I don't know the specifics of your device, many health apps or devices allow manual adjustments to calorie recommendations. Look for settings tracking locate that allow you to customize your goals based on your height, weight, activity level, and desired maintenance plan. Remember, it's crucial to follow a balanced and sustainable plan that works for you. Always consult with a healthcare professional for personalized advice.
