07-08-2025 12:01
07-08-2025 12:01
How can you manually enter you weight , BMI and so on , this will give you where u wanna be in the future
Best Answer07-09-2025 11:14
07-09-2025 11:14
Hello @Kennyghchvjvdf
I moved your post from the Ace LTE product help forum, which is a Fitbit for children, to the Manage Weight forum, a better place for your question.
To enter your weight and other details, tap on the You tab at the bottom of the Today page. Then tap on Edit profile. This will open your profile page where you can enter/edit your personal information.
If what you are want to do is set your goals, swipe up on the You page to get to the Goals section. Tap on See all on the right side of Goal. Here's where you can set or edit your various goals.
Please let us know if this answered your question.
Best Answer07-09-2025 15:50
07-09-2025 15:50
Best Answer07-11-2025 15:44
07-11-2025 15:44
The goals that you see in the Fitbit app are the only ones that the app supports.
It sounds like you need a 3rd party app to help you track those other goals.
Best Answer07-13-2025 07:10
07-13-2025 07:10
@Kennyghchvjvdf BMI is calculated from your height and weight. Setting a weight goal will give you a BMI goal. There is a page in the app that lets you set a % body fat goal. If you migrated to a Google account, tap on your profile picture > Fitbit settings > Nutrition & weight, you should get this page:
You can set a goal % body fat. I never entered one. I don't know how you monitor it.
I don't understand what you want to change with Quick reply. Here is a link to Fitbit's Help article. Quick replies are only available on Android phones. This is an Apple limitation and there is nothing Fitbit can do about it.
Laurie | Maryland
