08-17-2017 10:14
08-17-2017 10:14
Hi new to using Fitbit it's saying I've used 2467 calories roughly the last 3 days would this be correct I'm 5ft 1 female and 11st 8 thanks
Best Answer08-17-2017 10:36
08-17-2017 10:36
Hello @Vslskihepp, i would do a search for a "BMR calculator", theor are several on the web. Your weight and age will also need to be considered in the BMR calculations.
I have also moved your post to the discussion area, since it is not a direct question about a single tracker, and more on the way Fitbit does things.
Best Answer08-17-2017 10:46
08-17-2017 10:46
Hi a bmr calculator calculating 1467 but Fitbit saying I've used approx 2469 calories , will Fitbit be accurate thanks
Best Answer08-17-2017 13:44
08-17-2017 13:44
What you get with Fitbit (calories burned) is TDEE, which is higher than BMR. Check this calculator, it includes definitions at the bottom.
Dominique | Finland
