Best AnswerYou are absolutely correct Deeds, 5lbs weighs 5lbs. Apparently many people find it easier to use the incorrect phrase 'weighs more" instead of the more correct phrase "is denser". If your clothes fit isn't changing then conversion from fat to muscle is not all that likely. Based on the fact that you have only made 2 posts, I am guessing that you haven't been at this for an extensive amount of time, so I will suggest that you give it a while longer, make sure you are logging your calories correctly (get a scale and weigh things), and maybe spend some time going back in the forums and see if the info there might help -
Your original post doesn't give a lot of detail about what you are hoping to use this tool to help you achieve but the oddas are very good that you can do it if you keep at it and are honest with yourself about what you are doing.
Good luck
Craig
