06-30-2024 16:05
06-30-2024 16:05
Hello all,
I've been in a -500 calorie deficit for about a month and one week. I took my starting weight, weighed everyday, and then weighed today. I only lost 2 ounces.
With that being said, I'm attaching a screenshot of my days. Most days I was within range, however I did have a good handful of red days. Does a two ounce loss add up for this month? I have issues with retaining water a lot because of hormones but I'm trying to increase water intake and I've been watching sodium. If this amount of red days would be enough to slow weight loss this much, I definitely understand but I'm very new to this so I'm not sure. Thoughts?
07-08-2024 14:01
07-08-2024 14:01
Mathematically impossible to gain weight in a consistent caloric deficit. Your number are off somewhere.
Best Answer07-28-2024 05:36
07-28-2024 05:36
The calorie burn figures from Fitbit can't be trusted unfortunately. Post here about my testing of it:
I doubt the problem applies just to me and I don't consider the calorie burn feature to be of much use. I use weight changes to gauge actual calorie deficit. If you lose 1Kg in a week, which very roughly 7,700 calories worth, your average daily deficit is 1,100 calories. Variations in body water weight (which, in large part, is about how much food is in your guts) make the calculation tricky. I took to weighing myself every morning after using the bathroom and averaging my weight readings for every day in a week. I would use the difference between each weekly average to estimate my calorie deficit. Still not perfect, but good enough to base adjustments to diet off of.
Bear in mind though that your body will respond to a significant weight loss situation by adjusting your metabolism to try to hold onto it's energy (fat) reserves. This, I believe, is the cause of weight-loss 'plateaus'. You may need to lower your calorie intake over time to maintain a fixed calorie deficit and hit a target weight loss rate.
Very best of luck!
Best Answer08-10-2024 07:36
08-10-2024 07:36
Hi! A 2-ounce loss over a month on a -500 calorie deficit seems unusual, especially with red days. Hormonal water retention might be affecting results. Consider tracking more closely and reviewing your diet and exercise consistency.
Best Answer09-14-2024 04:04
09-14-2024 04:04
Being in a calorie deficit is not a magic key.
You have to understand that apart from calorie deficit you have to choose food that brings satiety.
If you eat Snickers or drink Coca-Cola and count it (or even not count coca-cola as some think that if it's liquid it's fine) you doing a disservice to your weight-loss process.
Even more, the calorie deficit can stunt growth, so you have to be extra cautious if you're in your younger ages, when you hope to grow taller and stronger.
You have to have a healthy diet and provide your body with all needed nutrition.
Take care!
