@beckyneilsen wrote:
I would like to know why, when I record my weight, the amount immediately decreases by a tenth or two? For instance I recorded 174.8 and it immediately changed to 174.7. Several times it changed by two tenths and once by three.
@beckyneilsenMany of us have reported this issue and Fitbit have a tendency to apply some odd rounding issues in their mathematics even though yours is a whole number. My goal weight is 81kg but is displayed as 80.9kg, a similar proportion to your issue. My actual weight shows as correct, but 3 months ago I had the decimal variation.
Best AnswerDo you enter it via the website or the app, or synced from say MFP?
Best AnswerI always record my weight on the website. The funny thing is I can weigh 156 pounds or 158 pounds but if I enter 157 it changes to 156.9. Apparently I am not alowed to weigh 157 pounds. I havent made it down to 155 to find out if it is an even-odd problem. Interesting don't you think. I hope there is a solution at some point.
Best AnswerConversion. Most formulas use kg and cm, so conversion is done to that for storage.
Then your selection of units merely determines the conversion to display what has been logged.
157 lb = 71.2 kg
71.2 kg = 156.9 lbs
They aren't logging enough significant digits for good conversion, or need to reexamine their rounding routines.
You can catch that on many numbers.
@Heybales wrote:Conversion. Most formulas use kg and cm, so conversion is done to that for storage.
157 lb = 71.2 kg
71.2 kg = 156.9 lbs
You can log your 157 weight as 157.01 and it will round to 157.
