im having trouble finding some good brands that can keep the girls in place while i do athletic activities. i just cant seem to find one that works. im a 36/38 C cup. please help me locate a brand/shop thats sells good quality sports bra's and other sports clothing.
@Game-Nerd wrote:im having trouble finding some good brands that can keep the girls in place while i do athletic activities. i just cant seem to find one that works. im a 36/38 C cup. please help me locate a brand/shop thats sells good quality sports bra's and other sports clothing.
you can try fleet feet
Best AnswerI wear a 34 DD and buy these at Macy's, I love them! In fact I wear them every day whether I work out or not.
Wacoal Sport Underwire Bra 855170
Best AnswerI swear by Oprah's choice, Enell (with front hook and eye fasteners), and have used two of these for several years now. Try them on whenever possible (I found mine to try at Running Store in Carlsbad CA). I ordered through Ebay, wherever I found best price after sizing. I have nude and black, and like two choices. Holds you firmly in place and no bounce. AWESOME!!! And no underwires needed.
Best AnswerI'm a 36DD and got a couple of sports bras on sale at Old Navy for about $12 a piece. I can't remember which ones exactly they were now, but I got the ones with the most support that Old Navy has (they have 3 different "levels" of support for the sports bras if I remember right). I love them and have had them for over a year now with no complaints.
Best AnswerI am a chesty girl (34G, ugh). The only way I can find enough support is by wearing 2 sports bras, one for coverage (my normal size) and then one for control (a size smaller). It is not particularly comfortable but it locks and loads the girls enough that I can do jazzercise and other very bouncy activities without feeling the need to hold onto my boobs to stop them from bouncing. I am optomistic that at the end of my weightloss journey (14 lbs down, 10 more to go) I will be down to possibly an E cup, which may be easier to tame while exercising.
Best AnswerI'd check with Torrid or Lane Bryant (which has a surprising focus on fitness wear) with your size. I see C cups all the time at those locations.
I am a 38 J and have often gone the custom route. But like others have said Wacoal is a good brand for bigger cups even with their everyday line. I find mine at Nordstroms, but they can be ordered online through many sources.
Don't be afraid to pay a little extra for a good bra, it will make all the difference to your workout! 🙂
Best AnswerI had problems finding workout clothes especially Bra's that fit right and don't hurt. I was lucky enough that my local Walmart carries a large selection of large womens clothes and Bra's. I found some Bra's that went up high as well and they support pretty well. They are fruit of the Loom Brand. A friend of mine mentioned that they don't carry those at her Walmart but I am sure you can get it shipped to your store as well. Its not as expensive as Lane Bryant and co. so it works out well for me.
Best AnswerI'm a 36GG and have found that barenecessities.com has sports bras in my size. I also order from bravissimo.com.
I love the Panache line that both carry.
J
My wife has had great luck with Lane Bryant. It is normally very difficult for her to fine bras that fit comfortably yet with support
