12-26-2013 23:00
12-26-2013 23:00
Best Answer12-27-2013 07:50
12-27-2013 07:50
Have you had your lean mass vs. body fat determined? Since your BMI is pretty close to the middle of the normal range, you may want to focus on reducing centimeters and body fat % (if higher than average), rather than losing a lot of weight. You want to keep your lean mass (muscles) and chances are you would lose a lot by going down 14 kg from a very normal weight.
I bought the Aria scale three months after starting with Fitbit and my only regret is I didn't do it at the same time. Having a BMI of about 22, I no longer want to lose weight: I want to further decrease my body fat % and increase my lean mass. I find it's not easy to do both.
Dominique | Finland
Best Answer12-27-2013 01:42
12-27-2013 01:42
Your current BMI is 22.9, which is within the normal range. 50 kg would translate into a BMI of 17.9, probably too low for your own good. Do you really want to look like one of those anorexic teenage models fashion magazines are (unfortunately) full of?
Dominique | Finland
Best Answer12-27-2013 03:57
12-27-2013 03:57
12-27-2013 07:50
Dominique | Finland
Best Answer12-30-2013 10:30 - edited 12-30-2013 10:35
It is good to have a goal. You can change it when you like what you see in the mirror
fitbit says my bmi is 18.3 I am 5'6" 113-114, 51 yrs old
have you ever weighed your "goal weight" before?
Best Answer12-30-2013 13:35
12-30-2013 13:35
