No **ahem**.
Losing weight it’s difficult. If you don’t agree go to any store, mall etc. and look around you.
What do you see?
Almost 60-70% people are overweight. It’s a **ahem**ing plague in our time.
Solutions – many say simple. Nothing is simple.
Look at the amount of food that we eat, how the food is made, from what the food is made, all the additions to the food, and after all is cooked by the big companies the question remins….is really food what we eat?
Looks like it, tastes good but what is it that we eat?
@extra_medium wrote:
@divedragon wrote:
Carbs and especially simple carbs seem to increasae insulin production above that of fat or protiens. This extra insulin can result in the body attempting to store more fat even duirng a calorie deficit. This makes the old time calories in / calories out theory sometimes wrong.
Except your body can't just decide not to use the energy it needs to continue to operate, even if you ate nothing but spoonfuls of sugar - if you're in a caloric deficit over a given period of time you will lose weight.
It's hard to write a lot of books, get on talk shows or come up with fad diets based on calories in/calories out but that is really all that matters when it comes to weight loss/weight gain.
So it's taken me a while to respond to this. You're correct in that your body will use the energy it needs, but that doesn't mean that as a result of one (ie. insulin spike) a corresponding effect can occur (i.e.: hormonal reduction in metabolism) that changes the equation. Other factors such as timing can also affect what happens in the body. If you eat a meal high in simple carbs, you get a flood of glucose in the blood. This flood causes excess insulin to be generated in an attempt to lower blood glucose by storing it as fat. Each subsequent meal you eat will replishish blood glucose so if you are eating within a 6-10 hour window, your blood glucose may not go low enough to trigger the fat burning and if you do it won't be long enough to burn the amount of fat your body stored. Other hormones such as cortisol, the stress hormone, can also prevent fat oxidation, even under calorie restriction. This would probably result in a slowing of metobolism.
I'm including a couple of links to Dr. Fung's studies below. If you spend some time going through some of his blogs, you'll see a lot of evidence that demonstrate our hormones are a set of variables that the slightest imbalance can throw off what may seem intuitive.
https://intensivedietarymanagement.com/how-do-we-gain-weight-calories-part-1/
https://intensivedietarymanagement.com/atkins-decline-hormonal-obesity-part-xx/
