01-30-2014 11:23
01-30-2014 11:23
I'm curious if anyone has figured out how to convert our daily steps to WW points? I know that 2,000 steps equal 1 mile plus it's already listed on the Fit Bit. Any ideas? By not including the steps taken per day, you don't get an accurate accounting of activity done within the WW guidelines. Maybe doing both programs isn't the best idea?
Let me know what you think. Appreciate it...
01-30-2014 11:42
01-30-2014 11:42
On WW if you pull up the AP tracker and scroll to the bottom you will see there is a place to add steps
Wendy | CA | Moto G6 Android
01-30-2014 11:42
01-30-2014 11:42
01-30-2014 14:42
01-30-2014 14:42
Thank you SO MUCH! That works. You have no idea how many people don't know that on the web. Really appreciate it. Do you find there are many discrepancies between WW and the FitBit? My husband and I have done WW a few times, decided to go back after not getting quick enough results with the FitBit which we do love. Just rejoined WW today and attempting to put it all together.
04-17-2014 05:45
04-17-2014 05:45
04-18-2014 11:37
04-18-2014 11:37
In order to add steps you have to be on a computer, there isn't (yet, anyway) a way to do add from the mobile app.
Hope this helps!
04-19-2014 04:56
04-19-2014 04:56
05-09-2014 00:42
05-09-2014 00:42
How do you do this?? I cant work out how to
05-09-2014 05:09
05-09-2014 05:09
05-09-2014 05:20
05-09-2014 05:20
oh I am from australia maybe thats why I cant do it
05-09-2014 06:29
05-09-2014 06:29
I use the WW eTools and it's really easy.
1. Snyc your FitBit
2. Go to your FitBit Dashboard to see how many steps you have walked.
3. Go to the WW eTools and pull up the Activity tracker
4. At the bottom of the tracker there are two tabs, Quick Add and Add Steps
5. Select Add Steps
6. The first time you try to add steps you will need to configure your stride, there is a little icon you can click and WW will tell you how.
7. Enter your steps in the Number of Steps box and select All Day or Active. I usually select All Day and use my total steps for the day.
8. Click the tab Enter Steps
9. You will see your steps added in the Activity Tracker screen. For me it takes about 3000 steps to equal 1 AP, but it may vary depending on your stride.
Hope this helps!
05-09-2014 07:17
05-09-2014 07:17
Thanks Kindy but our etools must be different in australia we have the quick add but there is no add steps. I will just have to track the active exercise and the rest of the steps be an added bonus I guess without actually tracking them
05-09-2014 13:56
05-09-2014 13:56
05-09-2014 13:57
05-09-2014 13:57
02-06-2023 01:06
02-06-2023 01:06
It is very difficult for people who have been struggling with excess weight all their lives to regularly bring their bodies into shape. Discovered the best body restoration clinic https://vacuumbuttlift.com/
07-19-2023 07:41
07-19-2023 07:41
I'm actually having a similar dilemma, and I get that people are saying to just connect the Fitbit to the WW app.
There's a problem... the Fitbit I have is outdated, and it won't let me connect in the first place.
So if there's anyone out there that has some kind of formula or something that I can work with, preferably with steps (and even calories) instead of time because I accumulate my steps all throughout the day, that would mean a lot.
