Looks like the main change is in your exercising, not your diet. With all that new cardio added, you should burn more calories than before, so if you eat at the same level, you should have a bigger deficit than before (if you were already in a caloric deficit). Just give it some time and it should show on the scale.
Dominique | Finland
Same remarks as in this other topic: 1) sudden change in activity type/level/intensity can cause extra water retention (for instance, via increased cortisol production), 2) one week is too short a period to draw any meaninful conclusion.
Crossfit is known to be very demanding. What did your routine look like prior to it? Were you dieting with similar calories (2300 vs. 3000) prior to starting crossfit? If so, for how long and with what results?
Dominique | Finland
Best Answeryes ive just added this cardio this week, i use to just do weights but now i do 1 hour cardio extra and do less weights. my weights last for 40mins or so and the crossfit is about 1 hour, crossfit is like push ups, star jumps, planks, all that good stuff, its very demanding to what im use too
Dominique | Finland
