12-18-2014 05:45
12-18-2014 05:45
12-18-2014 05:51
12-18-2014 05:51
I weigh myself at zero AM daily. Right after using the restroom, weigh in. No foods and waters. Jotting down notes of what foods I should have avoided, what exercise regime changes I need and make adjustments.
12-18-2014 08:53
12-18-2014 08:53
Weigh after waking up and using the bathroom. If not needing to go, still weigh. In case of warm nights and dehydration, body fat reading can be off (higher) 'cause the body not being at it's natural water level. Possible to weigh, note that the estimated body fat can vary up to a few procent then, it's not possible when eating in moderation that the body fat has increased that much in a single day while being in deficit.
The body is more complex than calories in vs out. When weighing less, the body needs less energy (calories) to maintain or lose weight.
When exercising, weight can remain the same due muscles growing stronger, when loosing weight, most importantly that it comes from body fat. If the deficit is to high, since the body wants to survive, energy can be taken from muscles instead.
Keep a eye if body fat lowers, exercising stimulates the body to give up on body fat while providing enough protein, food.. during the day, so it doesn't think there's a food shortage and actually can hold onto body fat instead.
Eating protein (eggs, yoghurt, cheese,..) helps to prevent muscle loss and is used to repair the muscles.
Eating fruit (banana's, apples).. makes feeling fuller for longer including drinking water before eating, leading to automaticly eating less.
Try to get back in touch with your inner self:
Listening to your inner signals also helps to trust your body, when only eating while truly hungry also leads to eat less calories overall.
Its not the calories that count always but the food quality / quantity (nutritients it contains):
A chocolate bar and a piece of fruit (banana, apple) contains the same calories, though the fruit will let you stay longer satisfied while eating the chocolat bar, it's likely to be more hungry quicker and eating more, eating less calories automaticly.
When eating fruits, vegetables, proteins (in moderation), by not even counting calories, it's possible to eat a few hundred calories less automaticly and still loosing weight.
It's possible to track food while eating on instinct, but if not feeling hungry while the food plan says you can eat more, stop eating. Trust your inner self also (it knows the best when having eaten enough). ![]()
Best Answer12-18-2014 10:19
12-18-2014 10:19
Personally, I weigh myself right after I wake up and go to the bathroom - usually in the nude or with light clothing on. I believe it is the best time to do so since you haven't eaten or drank anything for at least a few hours. I have the bad habit of weighing myself every day, but only use my weight on one day a week to keep track of progress. Best of luck to you!
12-18-2014 13:04
12-18-2014 13:04
I think all of us would agree that first thing after the morning bathroom visit is the best.
12-22-2014 11:58
12-22-2014 11:58
Best Answer12-24-2014 04:47
12-24-2014 04:47
@ClayGillman wrote:I think all of us would agree that first thing after the morning bathroom visit is the best.
Agree - easiest way to ensure other variables remain constant! 🙂
Even then, I don't stress if I'm dying of thirst first thing in the morning and need a cup of water. I'm after big overall trends, not tiny little ones (which can be hormone-related for females anyway).
Best Answer12-24-2014 08:01
12-24-2014 08:01
Doesn't matter when you weigh. Weigh only once a week. There are many factors that make you fluctuate. You'll get the most valid assessment if you keep the variables the same (same time, if you've eaten or made a bowel movement)
Best Answer12-24-2014 20:00
12-24-2014 20:00
Best Answer12-25-2014 02:41 - edited 12-25-2014 02:44
Best Answer12-25-2014 12:10
12-25-2014 12:10
Best Answer12-25-2014 12:14
12-25-2014 12:14
Best Answer12-25-2014 12:16
12-25-2014 12:16
Best Answer12-26-2014 09:18
12-26-2014 09:18
@randiL I weigh in once a week, on my day off. I feel like weighing in more may put more pressure on the day to come.
I use my WiiFit board as a scale, since it keeps a record of my weight and BMI information as well, but setting it up on a flat surface (no carpets) usually displays an accurate number.
As a personal recommendation, follow your food plan as a guide and make sure you write down your meals as soon as you are about to get them; this will prevent the moment where you are holding your food log and remembering how much you ate and underestimating amounts. I have a tiny notebook where I write down the meals and their weight, so when I'm ready to write them down, they are accurate.
Get a food scale and measure everything. Increase your water intake and find different sources or variations for the meals you love that won't take a hit on your caloric budget.
Have a rest day! Enjoy your food and don't miss out on the opportunity to eat different.
Good luck! ![]()
