Hello guys,
Before I use to take a birth control pill for 84 days, it was 3 consecutive packs of the pills and then after a 1-week pause. And I did set my Female Health Tracking like this.
But now I am taking it monthly and I cannot edit the cycle length for 28 days.
I tried in the app and couldn't do it. I tried on the computer and I cannot even find the section to edit it.
Does someone know how to fix it?
Thank you.
Hi @PietraM and @AlbieE thank for posting your input here. Welcome to our new member. My apologies for the delay.
Sorry for the inconvenience with your Fitbit Health Tracking. Our team is working on finding the root cause in order to provide you with a resolution. Thanks for time that you've taken in order to fix it. I'll let you know as soon as we get more information about this.
I'll be around.
Best AnswerI’m having this issue. It’s frustrating seeing how LONG this issue has been known and not fixed. I work in software, and an app update shouldn’t take over a year.
To be clear - I have successfully updated my cycle to 28 days (from 33) in settings but the calendar and fertility tracking does NOT update.
Please get this fixed.
Hi! I have a suggestion to help remedy some of the difficulty in editing the cycle length in the women’s health tracker. I like the health tracker, but I find the circles don’t always move while in edit mode. Idea: To allow the Fitbit user the ability to type in directly the actual days of their monthly cycle. This would help the tracker to be more accurate as well. Thank you for considering this idea.
Best AnswerIts 2019 and I'm having the same issue. Any resolutions. Thanks
Been over a year now and this isn’t fixed. I too went from a 90 day cycle to a 28 day cycle and though my profile is correct and I update my periods, the calendar and predictions show the 90 day cycle. Why is this taking so long to fix? I feel sorry for the customer service rep who keeps thanking us for our patience and gives us empty promises. My husband and I are trying to have a baby and the fertile window predictions would be helpful if they’d ever work. There are other fitness trackers and apps that work. That may be our best answer.
So I was thinking I was crazy because I keep changing my cycle to 28 days and it won’t update on my calendar. My calendar says 38. Seems like this has been a problem for many. I’m flabbergasted that there is still no fix for this. This portion of Fitbit is useless. Can we get a real answer or fix by now?!
Wow, I am utterly shocked that I found this post, in April 2020, and the issue has still not been fixed by Fitbit...!!
had to fix it myself, see my response below 👍
Wow! Today I literally bought a pregnancy test because I have been stressed about being two days late since I changed birth control methods and edited my calendar to my new cycle. Turns out I wasn't two days late it was just a fitbit bug that they have known about for a year and a half. Sheesh!
This post has been up for over a year, I have been having this problem for months. Are there any solutions yet?
Also, does anyone recommend other period trackers since fitbit cannot resolve this?
thanks
I followed these directions several times and says it is saved, but doesn't. It's still off by 1 day than predicted
Best AnswerI literally did the same thing & bought a pregnancy test today since I just checked the app & it’s showing as 4 days late...then I realised the calendar hadn’t actually updated after I changed from a 28 to 33 day cycle. It’s been a nervous few days before I realised what was actually going on...
I have the same issue. Cycle set at 28 days but calendar says 51 and it WONT update. Hopefully Fitbit will address this issue which according to this thread has been identified for more than a year, for their female demographic!!!
LADIES I figured it out!!! I was having trouble with this myself. I think when you set the cycle length it’s for the initial predictions but once you start to log your periods it predicts your cycle length off of that!!
So if you want to change it, it’s annoying but it works, count the days back of the length you want and log a fake period. Do this for like the last 2 or 3 months and the cycle length should update.
For example if you want to changed it to 28 days as I wanted to, I had a period last week so I counted 28 days before that date and logged a fake one, and then did it for the month before that too.
Hope this helps everyone cause apparently the only feature specific to women doesn’t matter to Fitbit.
This totally works! I created and account just so I could upvote this because I was so frustrated while trying to figure this out and seeing the multi-year ignoring of the problem. Thank you!
Best AnswerThis makes me crazy. It was working fine up until the last couple months. I finally some how managed to get it from something ridiculous like 70-80 day cycle down to 35 days. It makes me not want to use it anymore and just go back to my old calendar
Best AnswerYou must have missed logging some periods. Go back through your history and DELETE any periods which are logged before your most recent chain of history. If you have logged every month’s period for the last year, say, then before that only logged sporadically, delete all those periods that were logged before the last year.
Best AnswerYou genius!! This totally worked thank you sooo much
