01-12-2019 23:48
01-12-2019 23:48
I have clicked to save my period and when I exit the screen and go back I get the welcome notes again and nothing is saved. I have version 2.85 and Google says I'm up to date. I have restarted my phone and the app. I have read through help and forums. What an missing?
Best Answer02-20-2019 17:30
02-20-2019 17:30
The problem seems to be resolved. I had reinstalled the software, rebooted etc. and nothing seemed to work, but the next day, I was able to add information that saved.
01-13-2019 07:59
01-13-2019 07:59
Hi @Mhulslp, welcome to the Forums! Thanks for the time you spent on the Community looking for a solution for this.
I'd suggest, deleting your Fitbit App and restarting your phone, then add back the Fitbit App and try it again following these steps.
If a period doesn’t meet the following requirements, you may receive an error and be unable to log the period:
Note that If you attempt to log a period in the future or a period with less than a one-day gap between periods, the pencil icon is unavailable. If you don’t see the pencil icon, make sure the period you’re attempting to log or edit meets all of the requirements.
I'll be around if you need further assistance!
02-13-2019 17:32
02-13-2019 17:32
I'm experiencing the same issue. I've reinstalled the app and still have the same problem. I log a period and it appears to save correctly. When I exit the female health section, then come back, I go to the welcome and initial female health setup. The saved period is no longer there.
02-14-2019 11:56
02-14-2019 11:56
Welcome on board @BW126, it's nice to see you around here! Sorry about what happened to your logged cycles, a couple of days ago we've noticed this issue has re-emerged this month. Thanks for reporting this you can follow all the details and contributed with updates in this thread. The problem has been escalated for investigation.
We appreciate your time and understanding while we're working on this. Please stay tuned and thank you for your patience. Let me know if you need anything else! ![]()
02-20-2019 14:53
02-20-2019 14:53
I'm experiencing exactly the same too. I keep re-adding the info but it disappears as soon as you leave the women's health.
02-20-2019 17:30
02-20-2019 17:30
02-20-2019 23:20
02-20-2019 23:20
02-21-2019 13:34 - edited 02-21-2019 13:46
Hi @Top2Toe and @BW126 nice to see you around. Thanks for confirming that this workaround has worked for you. We really appreciate your time and patience. This will help other users having similar issues.
Have a lovely day! I'll be around in case that you need anything else.
Best Answer05-29-2020 10:02
05-29-2020 10:02
Hi, this has been happening to me too. I've only logged one cycle, at the beginning of this month, but I just had to re-enter it. It looks like it saved but i keep having to go through the setup process every time I want to get to the calendar. The symptoms I tried to save for today keep disappearing and the cycle I logged doesn't show up on the daily main page when I go to those dates. I tried uninstalling, restarting, and reinstalling but it doesn't seem to be helping. I have a Samsung Galaxy Note 9 and it's running on up-to-date software.
06-21-2020 21:20
06-21-2020 21:20
I'm having the same issues. I have not tried deleting the app though.. if I delete it and then reinstall will I lose all of my data? I've been using the app for everything except cycle tracking since February.
06-22-2020 16:42
06-22-2020 16:42
I had the same issue, I got mine working by just uninstalling the app then reinstalling it and signed in using the same login info (same email address) and all my data was saved and tracker works now too
06-22-2020 16:44
06-22-2020 16:44
I had the same issue, I just got mine working by uninstalling the app then reinstalling it and signed in using the same login info (same email address) and all my data was saved and tracker works now too
07-02-2020 05:31
07-02-2020 05:31
Hello! I have tried updating the app, deleting and reinstalling the app and turning off the predictions on the Female Health in my Fit Bit app however it will not save any details other than the length of cycle- eg flow, symptoms etc.
Any other suggestions?
Thanks!
04-03-2021 00:46
04-03-2021 00:46
I’m having a problem with the calendar, when I go into it for my ovulation to look at the weeks in the month an such it’s set back to September of 1990 (I was only a month old). I’ve tried to delete the app and restart my phone and all that nothing helps. I have to literally scroll all the way down to this month to find my tracker.
04-09-2021 05:52
04-09-2021 05:52
I have this problem too, but my calendar defaults back to Oct 1977 every time I go into it. Have you managed to get it sorted yet?
04-11-2021 07:10
04-11-2021 07:10
Same problem here. Even when I try to scroll to today’s date, the app gets hung up. I can’t edit anything in the calendar.
04-11-2021 12:36
04-11-2021 12:36
Nope still does the same thing, I’m guessing it’s something Fitbit is going to have to fix.
04-11-2021 13:51
04-11-2021 13:51
Fingers crossed they fix it soon as it’s really annoying!
02-02-2022 05:46
02-02-2022 05:46
Hi
I have the same problem. Have uninstalled and reinstalled app but doesn't correct it (and do meet all the requirements listed above).
05-10-2022 09:52
05-10-2022 09:52
This issue I am experiencing already for 6 months and still no fix from fitbit. The work arounds aren't Working either...
So please fix this stupid annoying bug!
