07-19-2018
10:57
09:01
07-19-2018
10:57
09:01
Hi,
when im logging periods they don’t seem to always save. Also, I’m the settings I’ve put a 28 day cycle but in the calendar bit it says I’m on day x of 43. I don’t seem to be able to edit this. As a result my ‘fertility window’ is basically the same time as my period, but the app shows this just as blue rather than purple or pink. I have an apple phone and the latest version of the app. I’ve tried restarting my phone.
thanks
07-23-2018 09:01
07-23-2018 09:01
Welcome on board @Brunstable, it's nice to see a new member around! Thanks for letting us know about this issue about your periods not saving successfully. Our team is currently working to resolve this issue and hope to have a fix soon. Be sure to keep your Fitbit device and app up-to-date to ensure you receive the quickest resolution.
I appreciate your patience and look forward to getting you back on track.
Please let me know if there's anything we can do to assist you in the meantime.
Best Answer03-31-2019 05:38
03-31-2019 05:38
I’m having a similar issue. I’ve tried to log my period on a different date to when it was predicted. It’s deleted the predicted dates but when I’ve added it back in to the correct (past) date, it disappears after I press save!
Best Answer04-01-2019 05:38 - edited 05-20-2025 09:00
Welcome to the Fitbit Community @ALT1813! Thanks for trying to log your period on a different date to when it was predicted. Please, try doing the following:
Once you've done that, try going to Settings in the top right corner. It should bring up the option to remove "predictions". Turn it off, set your period then turn predictions back on.
I'll be around, keep me in the loop!
