06-03-2018 08:51
06-03-2018 08:51
The Female health tracker is saying that my period should start today but it won’t start until Wednesday. I have the cycle set as 27 days but then on another part of the tracker it says day 1 of 24 day cycle, not 27. Any ideas how to fix this?
Thanks
10-08-2018 05:37
10-08-2018 05:37
Welcome on board @Amy206, it's nice to see you around the forums! While in the period tracker, go to Settings in the top right corner. It should bring up the option to remove "predictions". Turn it off, set your period then turn predictions back on. This way it seems to just put in your average period days and not what the predicted end date would've been.
Give this a go and let me know if this works!
06-03-2018 09:01
06-03-2018 09:01
I was wondering the same thing. As i try to go change the settings it freezing the entire app. Please help!
06-03-2018 11:19
06-03-2018 11:19
Both of you, there is a separate Forum for Female Health Tracking problems now. You are much more likely to get an answer to your problems there.
06-03-2018 12:08
06-03-2018 12:08
Thanks
06-03-2018 12:11
06-03-2018 12:11
Thanks, I posted it over there 🙂
06-04-2018 04:05
06-04-2018 04:05
Please let me know if you find a solution to this as I am having the same issue.
06-04-2018 08:47
06-04-2018 08:47
Hey there @DisaJan @December2012 @daniellemarie94, it's nice to see you around!
I think the app might be frozen. So, I'd recommend trying the following:
Thanks for keeping the Community Forums organized @SunsetRunner!
Looking forward to your response!
10-07-2018 18:49
10-07-2018 18:49
It keeps saying that my period is in one day but it’s not supposed to start for about 2 weeks and then when u do get my period it gets all screwed up? How do I fix this?
10-08-2018 05:37
10-08-2018 05:37
10-08-2018 11:11
10-08-2018 11:11
Hi MarreFitbit, thanks for the tip. It does work but on the dash board it just says “Female Health Tracking” but it worked! Thanks a lot!
10-12-2018 05:03
10-12-2018 05:03
Yay! Music to my ears @Amy206. I'm glad to hear it worked, thanks for sharing the outcome my friend.
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
05-10-2019 14:24
05-10-2019 14:24
I've tried changing the cycle days, I've tried logging out, I've tried everything noted here. However, it still shows 21 days rather than 28. Thoughts? I may just turn off predictions since it won't update. HELP!
05-14-2019 14:11
05-14-2019 14:11
Hi @malter23 thanks for getting back to the Fitbit Forums. My apologies for the delay.
I appreciate the steps you've tried to change your cycle days. Can you please check if your Fitbit app up to date. You can also try to uninstall and reinstall the Fitbit app to see if this helps. Confirm that you are following each of the steps suggested here.
Keep me posted.
05-14-2019 15:29
05-14-2019 15:29
05-15-2019 10:42 - edited 05-15-2019 10:42
Hi there @malter23, thanks for coming back and for trying the tips and recommendations provided here.
I was about to create a support case on your behalf, but I've seen you contacted our Support Team after posting here. Some will contact you soon!
Let us know if there's anything else I may do to assist you with.
07-05-2019 07:07
07-05-2019 07:07
I’ve edited. I’ve updated. I’ve logged out. I’ve rebooted. No matter what I do, Cycle Day in Female Tracker in Charge 3 will not change from 25 to 23. This is very frustrating. Advise please.
07-06-2019 08:17 - edited 07-06-2019 10:24
Hi @Mpower123 welcome the Community Forums. Nice to see you around.
Thanks for following all those steps, sorry to see they didn't solve the issue with the Female Health details on your Charge 3.
If your Fitbit app on your phone is also showing incorrect information, please try the steps suggested by @MarreFitbit here. Then you can sync your Fitbit Charge 3 to see if this changes the information on your device. Otherwise, please remove your Fitbit Charge 3 from the Fitbit app and add it back as a new device.
Let me know how it works.
08-08-2019 23:05
08-08-2019 23:05
This didn’t resolve the problem for me. Any further ideas please?
08-12-2019 13:05 - edited 08-12-2019 13:06
Welcome to the Community Forums @KatieButtercup! Thanks for stopping by and following the steps I've provided above.
If you have trouble adding or editing a period, see our troubleshooting tips.
During your predicted period, you’re asked to confirm whether your period started. Tap or click Yes to confirm that your period started or Not Yet if it hasn’t started. Tap or click Edit to adjust the dates before you confirm your period.
If you confirm a predicted period, the predicted period becomes a confirmed period. If you don’t confirm a predicted period, the prediction remains on your calendar. After the last day of the prediction window passes, the entire predicted period shifts to the next day. Note that the calendar doesn’t update until after midnight.
Give this a go and let me know if this works.
08-12-2019 13:08
08-12-2019 13:08
