11-23-2021 08:18
11-23-2021 08:18
Heh there. I’m keen on monitoring my active minutes via my Versa 3. I had the strangest experience yesterday whilst on a 2 hour Zoom call. My heart rate must have zoomed up as I collected 99 active zone minutes! No feelings of pain or anything. My fitness is a bit below where I want it to be but I’m not bad for a 62 year old.
Anybody had this? My only explanation is stress (I was writing furiously throughout as I was taking the notes) and Diet Coke!
Best Answer12-06-2021 16:05
12-06-2021 16:05
I find the more animated I am in the discussion, the higher my HR is during work meetings. Diet coke is for sure a contributor. I do think the prolonged HR for 99 active minutes may have been a glitch. I can see maybe 15, 20..99 seems a bit much, but depending on the discussion and your note taking, maybe. Check your stats on other calls that are going to happen and see if you have a similar experience.
Elena | Pennsylvania
Best Answer12-03-2021 13:26 - edited 12-03-2021 13:27
For a high stress call, your experience doesn't sound terribly unusual; especially for those of us of a "certain age" (I'm a couple years older than you).
I just looked at a few Zoom meetings I've had over the last couple of weeks and see a similar result, my typical "working" (I have a desk job) RHR is in the mid 40s, however, it looks like I typically bump up into the low to mid 80s for at least a portion of every call, and I did find one call two weeks ago where I hit 97.
12-06-2021 16:05
12-06-2021 16:05
Best Answer12-30-2021 10:30
12-30-2021 10:30
Thanks. Yes of a certain age!
12-30-2021 10:31
12-30-2021 10:31
Thanks Emili. Makes sense.
