11-23-2023 02:05
11-23-2023 02:05
Just for information - there are a number of questions on this topic where the problem is that (in a supported region) it is impossible to complete setup of the irregular heart notification setup because the Next button is greyed out. There is a section which should be above this screen which requires you to verify your age, and in this scenario it doesn't show up so you can't continue. Other people have suggested that by scrolling hard up and down and/or scrolling in different parts of the screen - you could make the option appear. This never worked for me.
However I just noticed what my problem was. I use reading glasses for small print, and as I don't like wearing them to look at my phone, I had turned the text size up in the general settings for my iPhone. Setting them back to the default made the age verification section and enabled me to complete setup.
01-12-2024 16:51
01-12-2024 16:51
Hallelujah guys and gals, finally they have updated the app and the afib is able to be setup. I have been checking the play store everyday for fitbit app updates and they just released the app update an hour ago and I am now able to setup the afib feature 🙂 Good health everyone!
Best Answer01-14-2024 02:14
01-14-2024 02:14
It’s still not working for me with the newest version of the app.
Best Answer01-14-2024 05:29
01-14-2024 05:29
Mine is still not working either. Don't see any update 😞
Best Answer01-16-2024 13:34
01-16-2024 13:34
Hello all,
According to a recent Moderator post, Fitbit app version 4.08 should be rolled out to all users by the end of this week (19 Jan 2024).
Like others, I'm still on app version 4.06 and waiting for the app update to be available for me to install.
01-16-2024 13:39
01-16-2024 13:39
Best Answer01-16-2024 17:23
01-16-2024 17:23
I didn't think it would work, but changing the font size to very small and voila! There was (seemingly) a whole other page with fields to verify age/aFib status. Thank you for the tip!
01-16-2024 17:41
01-16-2024 17:41
FYI, received 4.08 update tonight and installed it. Setup now works fine just like before 👍.
Hooray...
01-17-2024 00:03
01-17-2024 00:03
Hooray the update has fixed it. What a faff!
Thanks for the communications people!
01-19-2024 09:46
01-19-2024 09:46
THANK YOU~ I have my font size up on my phone too! When I turned it down, there it was: A TOTALLY different screen allowing me to verify age and AFib.
Super appreciative.
JTeach
01-26-2024 16:10
01-26-2024 16:10
I had a problem where irregular heartbeat function was not reporting. After restoring the app, restoring the Charge 5, restoring the iPhone. It still didn't update the IH info. So I turned off the feature only to run into the problem of the greyed out 'next' field when I attempted to turn it on again. Yes, changing the iPhone default font size to small fixed the problem and I was able to turn on IH reporting. Never would I ever have come up with the idea that the font size was a problem. Thanks for this info! Pretty big bug if you ask me! Hey Fitbit...are you listening?????
Best Answer01-26-2024 17:43
01-26-2024 17:43
Update came through and my irregular rhythm notifications working now. Finally. Pleased.
(Android, Canada).
01-31-2024 08:20
01-31-2024 08:20
Mine was the same with the grayed out box. I deleted the app and re-downloaded and signed in. Still same. What the issue for me is was that my text size on my phone was set too large and it was making the afib diagnosis question was not showing. Once I changed don't size to smaller, that box appeared and I answered. Voila! I could finally move past that screen!
01-31-2024 11:10
01-31-2024 11:10
Best Answer02-02-2024 08:40
02-02-2024 08:40
I had the same problem and only was able to fix it due to your post! I also decreased the size of my font on my Android, went back to the Fitbit app and was then able to see the full details when trying to set the Irregular Rhythm Notifications up. Thanks!!!!
02-07-2024 09:56
02-07-2024 09:56
my next is grayed out so any idea how to fix?
Best Answer02-15-2024 11:39
02-15-2024 11:39
Thank you so much for your answer. I also had to change the text size so the other box would show up on the screen. You're a genius!
02-24-2024 11:27
02-24-2024 11:27
03-07-2024 07:16
03-07-2024 07:16
This solution worked for me as well.
04-01-2024 13:52
04-01-2024 13:52
Thank you! If I'm here, did I get through? lol
I had Recent brain surgery and am still recovering and want to use my Fitbit to the max to keep better record of my health issues 🙌
04-01-2024 13:56
04-01-2024 13:56
Thank you, it worked!
(This msg might be somewhere else. I just started navigating, so I apologize if I boo-boo'd 🤗
