06-17-2017 02:05
06-17-2017 02:05
This morning after syncing the active minutes from yesterday have disappeared. They were there yesterday evening and I have not entered any active minutes.
Any advice please.
06-30-2017 12:52
06-30-2017 12:52
Hey there @Kisimul! This seems pretty weird. I would like you to double check that there are no activities logged in your Dashboard that may be deleting the active minutes.
Also, please answer to the following questions:
- Is any other data missing in your Dashboard?
- Has this happened before?
- How many active minutes did you have?
- Are you using the app or online Dashboard?
Keep me posted!
Best Answer07-09-2017 03:50
07-09-2017 03:50
Same is happening to my One. The minutes flash up when I first sync but by the time the other data is added, the active minutes has disappeared! Also when I log exercise, the time is not added to active minutes either so it's been reading as zero for days now.
06:11
12:08
07-10-2017
06:11
12:08
Hey there @Wally68! Sometimes what happens is that when users are logging activities and using their trackers, the data gets override. So, at the end you don't get active minutes because they are being deleted if you log activities and the data that you get is lower than what you got from your Fitbit tracker.
I would like you to double check if you have activities in the times that you should have active minutes and delete them.
Traditionally, you can learn more about when to log activities and when to use your tracker by checking this article How do I track my exercise and activities with Fitbit?.
Hope this helps!
