09-13-2016 23:13
09-13-2016 23:13
Best Answer09-14-2016 02:23
09-14-2016 02:23
Hi, @Nibrocmc, that's a little unusual for the One -- it is more common in the wrist worn trackers in my experience. I would suggest if you are wearing it on a hip or back pocket to clip it somewhere higher on your body if possible -- but always making sure it isn't bouncing about.
If that doesn't help, I notice that you are using an Android device. In that case you can download a free app called DriveBit that will automatically create a driving activity for you on your activity log. Creating a driving activity will negate any steps picked up in the time. I have tried DriveBit, and it works very well.
You can also create the driving activity manually yourself. Instructions here.
I hope this helps. Welcome to the Community!
09-14-2016 02:23
