06-30-2018
02:03
08:12
SantiR
06-30-2018
02:03
08:12
SantiR
Has anyone else noticed Fitbit One battery life suddenly fallen off a cliff? Up to about 10 days ago I was getting a good 5 or more days life out of mine. Now I'm lucky to get 2 days. This happened in the past due to some software update that they eventually sorted. Am I the only person experiencing this?
Moderator Edit: Updated Subject for Clarity
Would you happen to use an iPhone with your fitbit and just done an iOS update? There is a known bug with One battery life documented here: https://community.fitbit.com/t5/One/One-battery-draining-quickly-after-2-41-1-iOS-update/td-p/224778...
Best AnswerI also am having problems with battery life. I typically charge my One about once a week. This week, I have charged it three times.
I also am having an issue with syncing to my computer through the dongle. The computer shows the dongle is connected, but it cannot find my One. I get the following message, offering that I try again:
Does your tracker have power?
Make sure your tracker's display turns on
and it is close to the Wireless Sync Dongle.
The tracker is fully charged and very close to the dongle. I have tried removing and replacing the dongle. I seem to be able to sync OK through my phone.
What might I do next?
Best AnswerMine is syncing again fine now. Thanks. I will watch the battery life this week. Last week may have been a fluke . . . .
08:09
11:55
07-04-2018
08:09
11:55
@Polargonk @tennistitan Welcome to the Fitbit Community! Thanks for reporting the situation you are experiencing with your One's battery.
I'd recommend checking these tips to improve your One's battery power. This has helped other users in the past.
@tennistitan I'm really glad to read that customer support is sending you a new one. Please follow these replacement set up steps for you to not loose any of your previous data.
@joanheminway I hope you're doing well! Thanks for reporting the situation with your One's battery and syncing capabilities.
I'm glad to read that yours is syncing properly now. Please try the improve battery tips shared on the link above and watch if the battery betters itself.
@SteveH Thanks for your great help on this thread!
Hope this helps. Keep me posted! ![]()
