03-20-2016 17:08
03-20-2016 17:08
Best Answer03-20-2016 18:38
03-20-2016 18:38
Hi @neecee6. This phone does not show on Fitbit's compatibility list, so I suspect that it will not sync.
Here is the pertinent link: https://www.fitbit.com/ca/devices
TW
Best Answer03-20-2016 19:14
03-20-2016 19:14
I've been using an Alcatel One Touch Pop Icon A564C with my Fitbits for six months with no problems. I'm not sure why Alcatel isn't on the compatibility list, but that model, at least, works flawlessly for me.
Hope this helps!
Charge HR, Flex | Windows 10 | Android | iPad
07-15-2017 19:16
07-15-2017 19:16
Please tell me which phone brand you used to connect your Alcatel One Touch to your Fitbit. Thanks
Best Answer07-16-2017 06:14
07-16-2017 06:14
@sistahbabygirl wrote:Please tell me which phone brand you used to connect your Alcatel One Touch to your Fitbit. Thanks
Alcatel is the brand. One Touch Idol 3 is the model. It wasn't listed on supported devices when I first got the phone, but it does sync now. Thanks
Best Answer05-06-2020 20:45
05-06-2020 20:45
I am also attempting to use the Alcatel a564c with my FitBit, it will not communicate, the FitBit application says it can not connect. 😞
Best Answer05-06-2020 20:55
05-06-2020 20:55
Most new Android phones will just work.
By any chance are you upgrading phones (or do you have an existing phone that connects to Fitbit)? If so turn it (the old phone) off, and try using it with the new phone.
The old phone will interfere with it working on the new phone.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
