Fitbit Ultra Clock Faces and Syncing
ANSWERED
Good morning! Advise please how to propose a clock on my device of Fitbit F004 and how to conduct synchronization of my device with a computer as that program for Fitbit I can not load through that that a server does not answer and for me Windows 7 64bit, but not Windows 10?
Moderator Edit: Updated Subject for Clarity
1 BEST ANSWER
Accepted Solutions
The Fitbit F004 is a long discontinued Fitbit Ultra. It does not have customizable clock faces and there is no SDK available to do anything with it.
You can find the manual here. For the software go here and try either the download link for "PC" or the one for "Windows XP".
4 REPLIES 4
@Sergijko Welcome to the Fitbit forums! Thanks for taking the time to post on this board regarding your Fitbit Ultra.
Fitbit Ultra is no longer supported by Fitbit. It is not possible to propose clock faces for this tracker.
However, please try what @SunsetRunner suggested on his post and if you are able to set it up and sync; please do let me know!
Keep me posted! Smiley Happy
Santi | Community Moderator, Fitbit
Like my response? Vote for it! Also, accept as solution!
 Setting synchronization was not succeeded, during synchronization a report shoots out from Internet Explorer
"fitbit" - determination is absent
code: 0
file://C:Documents of and of SettingsSamsung - PCLocal SettingsTemp71e89435 - 8c41-43db-9db7-234c0dbab6a4.html
Program is set on Windows XP Servis Pack 3
Restarts changed nothing
@Sergijko Thanks for your reply and for sharing the experience you have had while trying to set up and sync the Ultra.
I'd recommend checking the new generation of Fitbit devices. They have a lot of new features you will surely enjoy.
See you around! Smiley Happy
