11-25-2017
01:30
09:21
SantiR
11-25-2017
01:30
09:21
SantiR
When I go for a walk using GPS my ONE It no longer shows me the map with distance and where I've walked etc has anyone had this problem and know what to do to fix this because it use to give me this information and now it doesn't
Moderator Edit: Updated Subject for Clarity
Best AnswerThe one does not have GPS tracking but it does have distance tracking, but if you want to track the way you walk you can get another tracker or use you're phone.
Go to track exercise, track( in the top right corner), and start
Best Answerthe one does not have GPS tracking but it does have distance tracking, but if you want to track the way you walk you can get another tracker or use you're phone.
Best AnswerMy fitbit one does have GPS tracking.. and i have MANY maps showing where i walked saved..
Lately it has not been working though.. i push start on the tracker and it starts the timer.. but doesnt show or save the map after i finish..
Not happy
Best AnswerIs it possible that you carried you’re phone around during the walks?
and:Help article: Does my Fitbit device have GPS?
09:20
15:39
11-27-2017
09:20
15:39
@Shellbell75 @cozyin2win Welcome to the Fitbit family! Thanks for reporting this. I made some research and found a thread that is compiling these reports; for Android users. Please, check this post and answer the questions there. That should help Fitbit to get a closer insight on this matter.
@ShaiKingTroy Thanks for your awesome help! ![]()
Also, thank you for sharing an alternative solutions that should help you in the meanwhile. That is great!
Thanks for your patience. See you around!
