04-12-2017 05:18
04-12-2017 05:18
I have only had my One for two days now, but I'm not sure if it really reporting the correct amount of steps or floors. I say this because it seems that I'm not really doing as much as it reports I am, as far as steps etc. I wear it at the torso as recommended. How do you check if the reading are really accurate? Thanks.
04-14-2017 07:38
04-14-2017 07:38
There is no step mode, and you do not have to record. Just walk 100 steps and see how many steps you gained
04-12-2017 06:59 - edited 04-12-2017 07:00
Floors you must go up at least 10 feet in elevation for it to count.
Do a 100 step test. Use the Start stop button to record and then walk and count 100 steps.
Mine has always been very accurate.
Wendy | CA | Moto G6 Android
04-12-2017 11:21
04-12-2017 11:21
To do this walk test, do I go to the step mode and then hold to clear, and then start recording? Thanks
04-14-2017 07:38
04-14-2017 07:38
