08:42
06:26
06-08-2016
08:42
06:26
Hello @Kbathe, welcome to our Fitbit community my friend. Well rest assure the missing clip is not affecting the battery, the bad news is that you have two different issues on your hands with your One.
Regarding the battery make sure is charging properly the charging cable. One of the reasons are dirty charging contacts, try to use hand sanitizer and a tissue or dampen a cotton swab with rubbing alcohol and carefully clean the charging contacts on your tracker and charger.
Keep in mind each alarm reduces battery life by small percentage. To maximize battery life, consider setting fewer alarms is is the case. Frequently pressing the button to check your statistics or the time may reduce the battery life too. Also if you're syncing with a device, the Always Connected option may reduce battery life.
If the issue persist even trying the previous suggestion please take a moment to reach out to our Support Team and let them know of your efforts to troubleshoot the issue and what you've already done. Don't forget to mention your belt clip has a missing part too. They will be able to advise you of the next steps after reviewing your device history with you.
Hope this helps and let me know how it goes.![]()
06-08-2016
10:22
06:25
06-08-2016
10:22
06:25
Welcome to the Community @Kbathe! Actually the fact that the bottom of your clip fell off doesn't have anything to do with those issues. Regarding the display and syncing issues, I would like you to perform a restart of it by following the instructions on this post.
Now, regarding the battery, please review the following tips to make the battery of your One last longer:
- Each alarm reduces battery life by small percentage. To maximize battery life, consider setting fewer alarms.
- Frequently pressing the button to check your statistics or the time may reduce the battery life.
- If you're syncing with an Android device, the Always Connected option may reduce battery life.
- If you're syncing with any Fitbit app, the All-Day sync option may reduce battery life.
- Charging your tracker in extreme heat or cold may reduce battery life.
Try those steps and let me know how it goes!
05:26
06:25
09:54
06:24
06-11-2016
09:54
06:24
@Kbathe how are you doin' today? Well, considering these issues, I urge you to contact Fitbit Support and let them know about this. I'm pretty sure they will find an alternative solution for you!
Have a nice weekend.
05:26
06:24
06-13-2016
05:26
06:24
Thank you so much for this collaboration @Dishman! I appreciate you have shared this with the Community. As you mentioned, sometimes it takes more time to sync your tracker when you recently updated the Fitbit app or the tracker itself. So that is why we suggest some tips to complete the syncing process.
It's great to hear that you get back on track!
Have an awesome week! ![]()
