02-08-2016 10:16
02-08-2016 10:16
I can't get my One to sync with either Fitbit Connect on my laptop OR on my iPhone all of a sudden. Tried rebooting computer and iPhone, no luck. On the phone it just says "Looking" forever. On the laptop it says "Searching for Fitbit tracker" for a long time and then goes to "not working? try again." Anyone know what might be up?
02-08-2016 16:39
02-08-2016 16:39
@Surfdog wrote:I've hadt he same problem for the past two weeks. Nothing syncs. Good luck getting help from Fitbit support.
FYI I reset the One (plugged it into charger plugged into laptop, held button down 12 seconds, unplugged it, held button til it turned on) and it syncs both places again. So maybe try that. My directions are probably less than stellar so you might want to look them up.
02-08-2016 10:26
02-08-2016 10:26
On the laptop do you have the Dongle plugged in?
Wendy | CA | Moto G6 Android
02-08-2016 10:26
02-08-2016 10:26
I've had the same problem for a few weeks now. Nothing seems to work for me.
02-08-2016 10:35
02-08-2016 16:26
02-08-2016 16:26
02-08-2016 16:38
02-08-2016 16:38
@WendyB wrote:On the laptop do you have the Dongle plugged in?
Yes, it's been plugged in all this time and always worked until now.
02-08-2016 16:39
02-08-2016 16:39
02-08-2016 17:18
02-08-2016 17:18
My fit bit one has also decided to not sync 4 days ago using windows 10. Have tried to get it to work on other computers and older with windos 7. It used to work, will not work now.
02-09-2016 03:22
02-09-2016 03:22
02-09-2016 16:43
02-09-2016 16:43
The reset worked. Thank you very much!
02-09-2016 22:00
02-09-2016 22:00
02-10-2016 05:16 - last edited on 02-10-2016 05:44 by HelenaFitbit
Thank you very much! The procedure to restart the fit bit worked. The fit bit is syncing again properly.
Moderator edit: Removed personal information.
02-10-2016 05:38
02-10-2016 05:38
@csc_dsb, @MorgnsGrl, @Dklvs, @missb267
Glad to hear that everything if fine. Yes, whenever there is trouble with the One or syncing, a successful restart is always the best #1 troubleshooting tip.
Thank you all for chiming in with an update. Have a nice day.
TW
05-09-2016 10:52
05-09-2016 10:52
I have the same problem. It used to sync fine, now it doesn't sync to my iPhone or PC. The dongle is plugged in. The iPhone looks and doesn't see it, the PC searches for a while then says not working. I tried restarting and factory reset a couple of times.
05-09-2016 13:33
05-09-2016 13:33
Hey @Lillia, thanks for stopping by! Have you tried setting up your tracker as a new device?
I'll be around!
06-01-2016 12:41
06-01-2016 12:41
I'm having the same issue. I have tried all suggestions. I have restarted it several times and on all of my devices it continues to say 'looking'. I'm frustrated.
06-02-2016 08:47
06-02-2016 08:47
Hey my friend @suz721, welcome to the Fitbit Community! Thanks for trying all the suggestions we shared here in order to solve the syncing issues.
At this point my best recommendation would be to get in touch with Customer Support directly so they can give you a hand on this. Don't forget to mention all the steps you've done so far to avoid getting the same ones.
You'll be in good hands!
06-03-2016 20:40
06-03-2016 20:40
The reset worked for me but two hours later I had to reset it again. Maybe it won't happen again and thanks for the tip on how to reset it.
06-04-2016 09:30
06-04-2016 09:30
Don't hesitate to keep us posted my friend @Beetle02 !
Hope to see you participating in the Community more often since I think it would be awesome for you to explore our Community, so you can go ahead and log to any of the topics that might be of your interest in our Discussion boards. Feel free to comment and contribute with your knowledge and experience.
Happy stepping!
06-04-2016 15:39
06-04-2016 15:39
Thank you! The reset solved this problem for me too. 🙂
