One Not Syncing After Being Washed
Recently washed fitbit one.  Also traveled to different time zone.  Now fitbit will not change time nor sync.
Bluetooth is on.
Help!
Ruth Hollifield
Moderator Edit: Updated Subject for Clarity
5 REPLIES 5
Welcome to the forums!
Did you put it in Rice for a few days to dry it out?
Try a restart. Do it at least 3 times.
Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
Check out the discussions boards! A lot going on and I'm sure you have some contributions as well!
Hope to see you around!
Community Council Member
Wendy | CA | Moto G6 Android
@woofie It's great to see you in the Fitbit forums! Thanks for taking the time to post the situation you are experiencing with your Fitbit One not syncing. It's unfortunate to read that it got washed. However, it's great that you have traveled!
The time is not changing because it is not syncing. However, once it syncs it should change the time to the correct one. In this case, I'd recommend performing all of these syncing troubleshooting steps to sort this out. Try the steps in the order given for best results.
Also, as it got washed, this may be happening as a result of moisture still being inside your tracker. So, have you tried @WendyB's suggestion already? Rice should take off any moisture left inside your One.
Try that out and let me know how it goes! Smiley Happy
Santi | Community Moderator, Fitbit
Like my response? Vote for it! Also, accept as solution!
Did all the recommended steps, but still did not sync.  Will have to buy a new one if I want to keep tracking.
I'm sorry it did not work.Contact support
http://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs
@woofie Thanks for your reply and for trying all of the recommended steps in order to sort this out. Have you thought on which one would you like to buy this time?
I went ahead and contacted you via PM. Please keep an eye on your Community inbox.
@WendyB Thanks for your help on this thread!
Hope this helps. Keep me posted! Smiley Happy
