02-07-2018
12:21
05:46
SantiR
02-07-2018
12:21
05:46
SantiR
I have been a fitbit one user for almost a year now (one year in april) and I love my little friend 😚😚😚😚 therefore I have a really big question. What is the best replacement for the one when I don't want to by the zip?
After looking in the different forums here I have read someone using the one in the socks and the end of jeans and so on... I have tried it myself and I must just say wow to the results! I must admit that I'm not sure if the kcal burn is correct, but if it is I just say wow!
Now my question is: I walk a lot, helping in a horse stable (with 13 horses), run (when I not have trouble with injuries) and do some exercise (one of them is yoga) and I need to track my sleep as well. I have seen on Amazon.com that there are a pouch/wallet that goes to the one (and flex 2) where you can have it on your leg, arm etc...
I want a tracker that can fit in there, and where I can see the display when I want. Just as I can with the one.
What to choose? I'm not a big fan of flex 2 and I'm also not a big fan of the zip.
Any suggestions? I will be grateful for any advice.
Moderator Edit: Updated Subject for Clarity/Format
Best Answer03-07-2018 18:13
03-07-2018 18:13
I have been researching the Garmin Vivofit 3 with the optional belt clip. Does everything the One does except floors. Vivofit 3 is waterproof and it can be paired with a chest strap heart rate monitor. I have posted on the Alternatives forum and have posted pictures of both clips. I will most likely switch to the Vivofit 3 when my One dies unless Fitbit comes up with a viable replacement.
Good luck to all of us that love our One.
02-07-2018 20:28 - edited 02-07-2018 20:52
I my self is very sad on the One demise.
If I was to pick a wrist model I would go for the Charge 2. It does everything. Work out mode, floors, etc. And its not big on the wrist.
I also would not get the Zip. I will get an Omron when my one dies. Its a very accurate pedo
Wendy | CA | Moto G6 Android
02-13-2018 12:33
02-13-2018 12:33
Thank you for the reply. Can you please tell me some more about the omron. How does it works, is it almost like the one, where to get it, what is the price? Etc.
Best Answer02-13-2018 20:12
02-13-2018 20:12
Check for yourself
https://omronhealthcare.com/fitness/
02-18-2018 10:50
02-18-2018 10:50
@WendyB: I have checked it out,and I must say that there aren't any that fit my taste as well as the fitbit one. I think I'll go for another fitbit,and then just get a clip to it (if possible) and/or a pouch to it. But thanks a lot for the suggestion 😊
03-07-2018 18:13
03-07-2018 18:13
03-08-2018 06:13
03-08-2018 06:13
Hi Everyone! I hope you're all doing well! Thank you for your feedback on the One.
Please see this thread for our statement on the One, there you can also join the conversation the One availability and alternative ideas. Since this is a duplicate thread, we will be closing it for further comments.
See you around!
