01-08-2016 14:24
01-08-2016 14:24
01-13-2016 07:28
01-13-2016 07:28
Welcome to the Forums @jpottiergrams! Did you do the initial set up of the tracker to your account? If you did not, you should check the detailed steps to do so. If you have set up your tracker and are still experiencing issues to sync please perform our recommended syncing troubleshooting steps based on the platform you are using.
Additionally, you can learn more about your One at the product manual, give it a look some time.
Thanks for your help @Rich_Laue!
Keep me posted on this!
Was this what you were looking for? Vote for it and mark it as an Accepted Solution!
01-08-2016 15:42 - edited 01-13-2016 10:23
Which screen amd which line is the Red Exclamation pointing to? If it doesn't say "can't find tracke4", what does it say?
01-12-2016 06:43
01-12-2016 06:43
01-13-2016 07:28
01-13-2016 07:28
01-19-2016 07:24
01-19-2016 07:24
01-19-2016 08:00
01-19-2016 08:00
Yei @jpottiergrams that's great! You are welcome! Helping each other is one of the main purposes of our great Community, we are glad you are now part of it!
Have you checked our Discussions board? There you can share your story, find some fitness tips, recipes and more! Give it a look!
See you around!
