09-01-2019 19:36
09-01-2019 19:36
Tried everything. Phone off, phone on. App uninstalled, app reinstalled. Reset one several times. Bluetooth on, bluetooth off. Pairing always rejected by one. Customer service said discount on new one, no help with problem. Works fine with dongle, just wont pair. At my wits end...like the one, dont want anything new. Any help will be greatly appreciated!
Best Answer09-02-2019 10:47
09-02-2019 10:47
Hello @Coke.d it sounds like you are trying to use the Bluetooth screen to pair your tracker. Please stop doing this, at best you will only get a message of "Rejected by the One".
You say it works fine with dongle, is this dongle connected to the unknown phone or the unknown computer?
If it works fine with the dongle then the tracker is setup. Install the Fitbit app on the phone, run the Fitbit app and log into your fitbit account. The app should ask for some permissions, you want to agree here, and the app should proceed to sync.
That is all you will need to do. If it fails to sync, we then have a sync issue and the first thing to try is removing the One from the phones Bluetooth.
09-02-2019 17:02
09-02-2019 17:02
Best Answer09-02-2019 17:30
09-02-2019 17:30
I have been having the same problem for the last week. Would appreciate knowing how to fix it.
Best Answer09-02-2019 17:37
09-02-2019 17:46
09-02-2019 17:46
Best Answer09-02-2019 17:53
09-02-2019 17:53
Best Answer09-02-2019 17:54
09-02-2019 17:54
Best Answer09-02-2019 17:58
09-02-2019 17:58
Best Answer09-15-2019 07:34
09-15-2019 07:34
