Hi. I bought a fit bit one from Fitbit through Amazon back in March. A couple of months ago the silicone case/clip split from the corner of the window section by about 3mm. I was afraid of losing the tracker so I purchased a replacement clip from Amazon (non original) but it's nothing like the same quality and I don't use for fear of losing. Would my warranty cover a new silicone clip (I stupidly didn't keep the split one) or is it something I can buy?
Thanks.
Best AnswerHi, @Tracey65! Fitbit Support should definitely be able to take care of you. I would suggest contacting them directly.
MakMak | Community Council
@Tracey65 welcome to the Fitbit family! Yay, those are amazing news.
Our Support Team is indeed wonderful. Thanks for keeping us updated.
Hope you get back on track as soon as possible! ![]()
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
