01-31-2017 02:59
01-31-2017 02:59
I cannot seem to get into alarms to delete alarms. I keep getting a pop up box telling me I have eight alarms and I need to delete some. Then poof -- nothing happens. Tried turning off my One, can't seem to find an alarm place in my online profile, everything syncs OK -- that's the extent of my knowledge. Anyone else had this problem?
01-31-2017 06:26 - edited 01-31-2017 06:27
Silet alarms is under settings then devices at the very top
It must sync before it takes place. Use the arrow on the right hand side to open it up. Then go in a select to turn them off
Wendy | CA | Moto G6 Android
01-31-2017 19:49
01-31-2017 19:49
Got it eventually. Not quite as you suggested but it gave me the courage to look harder. Didn't realize another screen would pop up when I touched the actual picture of the Fitbit One in the upper left hand corner of the screen. It's all easy if you know how! Thanks!
02-06-2017 09:08
02-06-2017 09:08
Thank you WendyB. This helped me fix my alarm problem.
02-26-2017 06:32
02-26-2017 06:32
@Froglegsforme @VPike Welcome to the Fitbit forums! I'm very glad to hear that @WendyB's post was helpful and that it fixed the problems you were experiencing.
Now, I recommend taking a look at the Discussions Board as you will find a lot of interesting things there. Feel free to post on any thread you want. If you are looking for Fitbit friends to compete with, check this friends thread to add some!
See you around!
