08-25-2020 12:48
08-25-2020 12:48
Is the usb dongle for syncing a fitbit one specific to that fitbit? I have two dongles from previous fitbit ones, but neither seems to work with my current fitbit one.
Best Answer08-25-2020 13:14
08-25-2020 13:14
Hi @NSta - Amazon offers a dongle that works with several older Fitbit devices, including the One. You can check that out. But I’m surprised your other dongles do not work. You may want to do some “googling” to see if there are other factors that may be the cause. Wish I could be more help but I’m afraid I have not used a One in many years.
08-26-2020 08:22
08-26-2020 08:22
Fitbits occasionally get in a confused state. I'd try restarting the tracker.
I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
08-28-2020 04:02
08-28-2020 04:02
Thanks very much for your reply. I tried that but it still reject pairing, but is transferring info from the fitbit tracker to my phone app!
Best Answer08-28-2020 04:04
08-28-2020 04:04
Thanks - the dongles still don't work and it also rejects bluetooth pairing, but somehow is still managing to transfer data from the fitbit to my phone app.
Best Answer09-16-2020 09:37
09-16-2020 09:37
What do you mean by rejecting the tracker @NSta?
Are you trying to pair the Fitbit One through the Bluetooth? A user will not be able to do this and should see a message of rejected by the One.
