I love my fitbit charge but looking for something I don't have to wear on my wrist for summer so got the fitbit one can I use the fitbit one in the day and the charge at night to track sleep and link together for data if that makes sense thanks
Best AnswerYes you can
in the latest update from Fitbit they a own ses that they will be able to change Fitbit automatically, as in you can you the one in the day and the Charge in the night! All you have to do is switch in between of a sync
It does make perfect sense, and yes you can!
You can connect multiple fitbits to the same fitbit account as long as they are different types. I have the One, Charge 2 and Blaze connected to mine.
It can get a bit confused if you wear more than one at the same time and I find it best to sync before swapping but it works fine. There's some more information on this here:
Yes you can
