06-18-2020
17:02
10:17
06-18-2020
17:02
10:17
I am planning a 5 day kayak trip. Will my charge 3 accumulate 5 days of paddling data or do I have to read the results off the watch each day. I will not have any access to a computer to download the data to my dashboard.
The unit stores 7 days of data. The following is from the user manual:
Memory
Charge 3 stores your data, including daily stats, sleep information, and exercise
history, for 7 days. Sync your tracker with the Fitbit app to access your historical
data. For best results, make sure the all-day sync option is turned on.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
18:13
21:57
06-18-2020
18:13
21:57
From How often should I sync my Fitbit device?
"We recommend that you sync your tracker or watch daily. Most Fitbit devices record detailed minute-by-minute data for 7 days. (Fitbit Alta records minute-by-minute data for five days). Fitbit devices can store daily totals for up to 30 days.
If you have a Fitbit Surge, your device can store 35 hours of GPS data before deleting some data to make room for more."
So you should be good.
