02-01-2020
18:47
10:23
02-01-2020
18:47
10:23
I was gifted a used Charge 2. I already have one that I am using. I wish to use both devices. The portal is not allowing me to activate the recently acquired Charge 2. It is only allowing replacement of the device. I repeat, can I activate both devices even if they are both Charge 2. They are different colors and do I need to activate the gifted one to use it?
02-01-2020 18:51
02-01-2020 18:51
I was gifted a used Charge 2. I already have one that I am using. I wish to use both devices. The portal is not allowing me to activate the recently acquired Charge 2. It is only allowing replacement of the device. I repeat, can I activate both devices even if they are both Charge 2. They are different colors and do I need to activate the gifted one to use it? I am syncing with an Android Max.
Best Answer02-01-2020 19:11
02-01-2020 19:11
Sorry but you cannot have 2 of the same device on same account.
The best you could do, though not a good option, would be to add the other as a replacement device each time you wanted to switch.
02-01-2020 20:23
02-01-2020 20:23
