01-16-2017
21:36
10:13
01-16-2017
21:36
10:13
I just recently got the charge 2 after my first charge took a crap. Either way, i have noticed that my charge 2 doesnt always record my active minutes. Its frustrating to see i work hard and get no show for my work. Any suggestions?
06-21-2017 14:17
06-21-2017 14:17
HeydyFitbit wrote:
@RJRose, welcome to the forums! By default, if you do at least 10 minutes of moderate to intense exercise, that time will be tracked as active minutes. However if you don't reach that time and reset your exercise, the minutes will be lost and won't count as active minutes. To learn more about how the active minutes work, please take a look at what I posted above.
It seems to me that the number of minutes of activity before active minutes are logged should be a personally configurable setting. If I want 5 continuous minutes of exercise to be considered "active", rather than 10 (or, more importantly, if I want 4 five-minute bursts of exercise to be considered 20 active minutes rather than zero), I should be able to tell the Fitbit to do that. I assume that's not possible at the moment, but it would be a good feature to add in the future.
Best Answer07-27-2017 14:21 - edited 07-27-2017 14:24
Hi there,
I've been reading everything and anything I can find on missing active minutes, but none of the "solutions" are working.
I have a Charge 2. When exercising it logs and displays my minutes. Upon completion of my exercise it shows in the excercise log my active minutes. The next time I login my active minutes are 0. In the exercise log for the particular exercise it shows "114 min. of 0 active min." My total active minutes are zeroed.
I have tried to set the tracker to active, I tried for it to self detect the exercise, but it all leads to the same result with 0 active minutes. I am beginning to get really frustrated! I even stoped synchronizing my Strava data and had to resort to using Strava as my main analyzing tool for my workouts. I never had this issue with my Charge HR.
please let me know how to fix this. As I mentioned before, nothing in the forum seems to resolve the problem.
Best,
Marion
Best Answer07-28-2017 09:32
07-28-2017 09:32
Hello Heydy,
My wife and I both have a Charge 2. Mine works fine but on her's the active minutes and calories are not.
Today we did three walks with a total of 168 minutes. I get 167 active minutes logged and she only gets 44 minutes. I get 1403 calories for these three walks and she only gets 327. My total calories for the day at 6:20pm are 3388 and her's are 922. The only difference I see is that my heart rate is 12-14 bpm higher than hers. I am around 115 and she is around 100. But also when she runs on the treadmill and has set the Charge2 to treadmill mode it does not count active minutes correctly. Sometimes she gets 0.
We approached fitbit with the issue. They sent her a replacement tracker, but the problem stays the same. Is there an issue with the iphone 6s? I have the iphone 6, she has a 6s.
I would appreciate any input on this. She gets quite frustrated over time. I am quite ok, because I win every day, although she is more active 😀😀 (just kidding).
Thank you!
Best regards
Philipp
Best Answer07-29-2017 02:15
07-29-2017 02:15
Best Answer08-06-2017 14:12
08-06-2017 14:12
I walk in the mall every day at the same pace the whole time & what my fit bit zip tracker is doing (all of a sudden) is dropping a whole bar out in the middle of the walk (which has not been even slowed let alone interrupted) so I will have several lines of green bars and then a completely blank one for five minute period right in the middle of it registering zero steps for that 5 min time frame even though I was continuously walking. This has happened on several occasions and it took me until I started specifically tracking every move so I could make sure I was following the protocol to realize that not only was it dropping a whole bar out it wasn't counting the steps at all during that timeslot. So for example if I started at the top of the hour and walked 60 min going 500steps every 5 minutes, at the end of the hour instead of registering 6000 steps it with only register 5500 on the graph, and 55 minutes of active minutes, but my step count on the fit bit itself would be at the full 6000. I'm using these numbers as a rounded off example but the concept is the same. Up until recently I would track my minutes by starting the clock and looking at that already active minutes before I started my daily walk to make sure and they always showed up exactly as I was doing them as long as I didn't stop in the middle thus breaking the chain of 10 minutes or more. This incident that has been happening recently is very new and wondering if I need to update my zip in someway?
Best Answer08-13-2017 23:45
08-13-2017 23:45
If I am racking up over 16000 steps in a day I know there is active minutes and yet I still had NONE recorded for the last 2 days .. frustrating
Best Answer08-18-2017 09:06
08-18-2017 09:06
Yesterday (8/17/2017), my active minutes were never recorded, both from my regular activity during the day and my specific active minutes from when I press the button in active mode. Today my active minutes were not recorded from my morning workout.
I went into the log activity mode and entered my time, but that doesn't show up either. Is there something I can do to reset this?
Note: FYI: As if this morning, I'm not able to input water.
Best Answer08-18-2017 09:07
08-18-2017 09:07
This does not answer my question.
Best Answer09-12-2017 02:20
09-12-2017 02:20
Mines set up for walking as a form off exercise I walk everyday to and from the gym it has logged this up until this week why has it stopped logging my walking I've not changed anything on my settings its being to bug me now please help
Best Answer09-12-2017 02:22
09-12-2017 02:22
You have to set it on your watch go into exercise and press the cross trainer or treadmill its like a timer I was the same u till I played around with my watch mines not logging my walks which I've not changed
Best Answer09-12-2017 06:07
09-12-2017 06:07
Best Answer09-12-2017 17:45
09-12-2017 17:45
Best Answer12-04-2017 18:36
12-04-2017 18:36
My bro does fewer steps than me and he gets more active minutes then me and I have way more steps then him and when we go grocery shopping we would have the same steps but I would not have the same active minutes
Best Answer01-22-2018 14:38
01-22-2018 14:38
Are my Workout minutes supposed to be included in the Active minutes? Sometimes they are not, only showing under Exercise. Thanks!
Best Answer03-23-2018 17:00
03-23-2018 17:00
What if your Fitbit completely stops tracking you active minutes? The last two days I have had no active minutes at all. I have never had a day without active minutes until 2 days ago. It recorded everything else correctly
Best Answer04-17-2018 15:16
04-17-2018 15:16
I just worked nonstop for 8 hours, no real standing stll, almost 60 floors, and it says no active minutes. Noticed it's done that for a while!
Best Answer04-17-2018 15:28
04-17-2018 15:28
Did you ever get active minutes for this time, @Tracylovesbeer
Best Answer04-17-2018 16:29
04-17-2018 16:29
2 things: 1) I find that when I input my water usage, it somehow spurs the steps and active minutes to update.
2) I find that if nothing works to sync my steps and/or active minutes, I turn off my phone completely, then turn it back on, and somehow it spurs an update.
Best Answer04-17-2018 21:57
04-17-2018 21:57
Best Answer04-17-2018 21:59
04-17-2018 21:59
