04-16-2018
06:04
18:54
04-16-2018
06:04
18:54
When I use the rowing machine my Charge 2 only tracks time. Why doesn’t it track active minutes? The heart rate shows that I’m in cardio the majority of the time.
04-17-2018 07:57
04-17-2018 07:57
Hey @61gray, let me give you a warm welcome to the Community! If your Charge 2 doesn't seem to be tracking your active minutes, could be because your exercise wasn't intense enough. Let me tell you that the duration isn't enough for your tracker to recognize active minutes, and I'll explain you why.
Fitbit devices calculate active minutes using metabolic equivalents (METs). METs help measure the energy expenditure of various activities. Because they do so in a comparable way among persons of different weights, METs are widely used as indicators for exercise intensity. For example, a MET of 1 indicates a body at rest. Fitbit devices estimate your MET value in any given minute by calculating the intensity of your activity.
You earn active minutes for activities at or above about 3 METs. To stay in line with the Center for Disease Control's (CDC’s) “10 minutes at a time is fine” concept, minutes are only awarded after 10 minutes of continuous moderate-to-intense activity. In other words, the intensity of exercise is key. So please take that into consideration and let me know how it goes!
I'll be around!
Best Answer04-17-2018 11:04
04-17-2018 11:04
Best Answer04-18-2018 06:21
04-18-2018 06:21
Thanks for your reply @61gray! Ok, let me ask you this, when rowing, are you seeing your heart rate on the machine or on the Charge 2 itself? I'm asking because maybe you are not correctly wearing your Fitbit and that is why your heart rate isn't very accurate while on the machine. So I'd like you to tell me, 'cause heart rate on these type of trackers directly interfere with active minutes. This is a possibility that I need to confirm so keep me posted! ![]()
Have a nice day!
Best Answer04-18-2018 06:31
04-18-2018 06:31
04-09-2020 10:09
04-09-2020 10:09
I have this exact same problem, and I check my heart rate on the FitBit frequently. It doesn’t record my heart rate correctly at all. And it’s not that I’m wearing it incorrectly, because I’ve tried every possible option: high up or low down on the arm; tight, middling or loose... it’s just not accurate at all, I’m afraid. Fine for gardening. Rubbish for sport.
