03-03-2018
09:05
18:54
03-03-2018
09:05
18:54
I found how to add Spinning onto my fitbit but what do I do now to track it?
When I go onto my tracker I only have the option to track Run,Walk and Hike.
Should it now automatically track spinning or have I done something wrong?
03-03-2018 13:35
03-03-2018 13:35
@Stainer When you say that you get run, walk, and hike, it sounds like you are using the Mobile Track feature -- this is where you tap on the exercise tile of the app dashboard, tap on the stopwatch, then you can start the exercise. This is the only tracking option that is just run, walk, and hike.
You need to be using your Charge 2 itself in the Multi-Sport mode to start your exercise. As you push the button on your tracker, you will scroll through your Display Items. Push the button until you get to the Exercise icon -- it should say Run. Now tap on the tracker until you get to Spinning. Press/hold the button to start/stop the exercise. A light press will pause the exercise. When you are done, you can scroll through your data for the exercise. It will go to your dashboard with the next sync.
Laurie | Maryland
03-03-2018 09:54
03-03-2018 09:54
You need to add it to your exercise shortcuts
On the computer Dashboard click on the gear and go to settings Then click on the device name and scroll until you see Exercise shortcuts. You can add up to 7 and arrange them how you want.
It will need to sync before it takes place on your device
Wendy | CA | Moto G6 Android
03-03-2018 10:54
03-03-2018 10:54
Hey, Thanks for replying.
I've already done that part its the next stage I don't know what to do.
Spinning is added but how do I get it to actually track. So far I have entered the data manually.
Best Answer03-03-2018 13:35
03-03-2018 13:35
Laurie | Maryland
03-04-2018 18:00
03-04-2018 18:00
Got it. I never realised you use the actual watch.
Thank you
Best Answer03-20-2019 13:29
03-20-2019 13:29
WendyB, yours was the only post that I could find to tell me how to add Spinning to my shortcuts. All the others just said select it from the watch. Thanks
