02-19-2018
18:18
18:54
02-19-2018
18:18
18:54
My Fitbit has lines in the screen. I’ve tried plugging it in the charger and resetting it but that seems to not work. What should I do?
02-20-2018 03:15
02-20-2018 03:15
Welcome to the Fitbit Community @SarahAS2244! Thanks for already troubleshooting this inconvenience with the screen of your Charge 2.
Would you mind to confirm if you've restarted your tracker by following these steps?
Also, please send me a picture showing the lines that your device has.
Looking forward to your response!
03-06-2018 13:07
03-06-2018 13:07
Hello! My Fitbit has had black lines going across the screen for a couple weeks now. I was wondering what I can do to fix it or if not what can I do? I did try to restart it and that did not do anything. Is there anything I can do or get a replacement?
03-08-2018 05:57
03-08-2018 05:57
Welcome to the Fitbit Community @LHoughton! That's odd. It could be one of two things, the screen was damaged because it was hit with or against something. Perhaps too much force was applied to it at one point or another. Was it, by any chance, dropped or hit by something?
Additionally, it could be a defect on the screen. In that case, is there any chance to take it back to the retailer (in case it was purchased through a retailer other that the Fitbit store) to for a replacement?
I would also like to request for a picture of the lines you're seeing on your Charge 2 display.
03-08-2018 06:20
03-08-2018 06:20
03-08-2018 06:44
03-08-2018 06:44
It will not let me post a picture.
03-08-2018 06:48
03-08-2018 06:58 - edited 03-08-2018 06:59
Thanks so much for the picture posted @LHoughton! I was about to create a support case on your behalf, but I have seen you already have one. Our team is looking to your response so they can move forward and get a resolution for the display not working. Have you check your inbox?
Please provide them with the same picture you just posted me here.
I'll be here if you have any questions!
03-08-2018 07:21
03-08-2018 07:21
Yes I have seen their email and have responded but I don't know if they received it.
05-28-2018 08:01
05-28-2018 08:01
Did you get a resolution to this? Mine started doing the same thing and the sleep cycles stopped working at the same time. I've had it year and a half and figure it's just at the end of its lifespan.
07-10-2018 16:33
07-10-2018 16:33
Yup, mine is missing a horizontal line as well. Tried the reset thing, didn't make a difference.
My Fitbit is about a year old.
07-10-2018 16:38
02-25-2019 22:28
02-25-2019 22:28
My Fitbit is doing the same thing. Am I able to get a replacement!!?
03-12-2019 19:04
03-12-2019 19:04
My Fitbit also has the same 2 lines across the top as show in the pic same.excat place I just bought mine in Nov. But hadn't notice it until I change the display of the clock
03-13-2019 06:02
03-13-2019 06:02
Mine has progressively gotten worse. This is what it looked like last night, this morning there were no identifiable #'s or letters.
Alberto
03-13-2019 06:04
03-13-2019 06:04
How did you post the image? I can't get my pic to show in message.
Albert
03-13-2019 07:00
03-13-2019 07:00
03-21-2019 09:12
03-21-2019 09:12
The same thing is happening to my Charge 3–2 thin black lines through the upper third of the screen. From what I’ve read, the problem gets worse. I’m not happy!
03-22-2019 04:18
03-22-2019 04:18
02-11-2020 09:34
02-11-2020 09:34
What was the outcome? Mine has stated to do the same. It's only 6 months old 😞
